Webcast-Catalyst9k
does 2960 support cab-sfp?
I came across the cab-sfp-50cm cable for interconnection of 3560 switches, but can't find any reference for the support of this cable on 2960 switches.
Does the 2960 support this cable or not?
Hans
1 REPLY
Re: does 2960 support cab-sfp?
The CAB-SFP-50CM is only for c3560 switches. You can not use it with 2960 switches
Q. What is the Cisco Catalyst 3560 SFP Interconnect Cable?
A. The Cisco Catalyst 3560 SFP Interconnect Cable provides for a low-cost point-to-point
Gigabit Ethernet connection between Catalyst 3560 switches. The 50cm cable is an
alternative to using SFP transceivers when interconnecting Catalyst 3560 switches through
their SFP ports over a short distance.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12220se1/3560hg/higoverv.htm#wp1129518
Hope it helps
Franco Zamora
1982
