Community Member
does 3750 Metro support MPLS?
Hi guys,
I choice two 3750 Metro with IP service license for a metropolitan network but now the customer asks me if they support MPLS.
I would like to know if I have to change the license up to IP advanced services or not.
Thanks in advance.
Regards.
Giuseppe
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: does 3750 Metro support MPLS?
Hello Giuseppe,
clearly the two tools are not aligned.
if we look at the MPLS confiugation of 12.2(44) SE
http://www.cisco.com/en/US/docs/switches/metro/catalyst3750m/software/release/12.2_46_se/configuration/guide/swmpls.html
it says the only limitation is:
The switch must connect to the MPLS network through an ES port. MPLS configuration is supported only on ES ports.
there is no mention of feature set and actually mpls is enabled by default on routed interfaces
I think this switch is thought to be used in metro and/or MPLS environment so it is reasonable that MPLS is supported in all releases/feature sets
Hope to help
Giuseppe
Hello Giuseppe,
I used feature navigator
www.cisco.com/go/fn
I selected search by plaform, I've specified IOS, c3750METRO, 12.2SE
it gives only two feature sets
EMI image
and EMI CRYPTO image
for example the EMI image:
Image Name c3750me-i5-mz.122-44.SE5.bin
DRAM / Min Flash 128 / 32
is declared to support MPLS including OSPF and EIGRP as PE-CE routing protocols
What image have you got on your C3750MEs ?
Hope to help
Giuseppe
Community Member
I used the feature navigator and I got to the same conclusion but my doubt is due to the fact that in my configuration there is Std Img with IP service license. Using the configuration tool there isn't EMI configuration for CAT3750ME. Moreover when I used the IOS software selector if I choice the MPLS feature there is any 3750 ME that is compliant with MPLS in anything configuration.
In conclusion, now using the standard Image because I can't change it (according to the configuration tool), what license do I have to use )?As mentioned-above the current is the IP service license.
I hope I explain it and you could answer me as soon as possible.
Thank you very much.
Regards.
Giuseppe
Hello Giuseppe,
Hope to help
Giuseppe
Hall of Fame Super Gold
Gee whiz guys! You two not only have the same names but work for the same company! Haven't you gents tried picking up the phone and calling each other?
He he he ... Joking only.
Hall of Fame Super Blue
Leo
Good spot :-)
Jon
282
