Does 3GE-GBIC-SC in 12000 suppoert q in q?
Hi All,
i am using Cisco 12000 router with 3GE-GBIC-SC module on the same. Since I am unable to do dot1q in dot1q, can any one suggest me if this module support this feature or not?
Thanks and Regards
Mangesh A. Bhende
Hall of Fame Super Silver
Re: Does 3GE-GBIC-SC in 12000 suppoert q in q?
Hello Mangesh,
as per feature navigator Q in Q is not supported on GSR
http://www.cisco.com/go/fn
I made a search by platform using 12000 PRP and I've found just 802.1Q support (1 tag)
This confirms my experience with GSR.
I would suggest for L2 transport to investigate EoMPLS that is supported on 3GE engine 2 linecard I did extensive tests on this.
In this way you should be able to transport QinQ frames over MPLS.
Hope to help
Giuseppe
Hi Giuseppe,
thank you very much and even i too think so.
Thanks and regards
Mangesh A. Bhende
131
