12-30-2013 02:39 PM - edited 03-07-2019 05:18 PM
Basically I'm using the IP 192.168.0.0/16 on a network I'm making.
I have:
Staff: 250 hosts
Support: 30 hosts
Admin: 8 hosts
Servers: 5 hosts
HR: 50 hosts
Do i need to basically add 1 on to each so staff is 251 hosts.
I know we need to use a default gateway for VLAN.
I'm going to be using a 4 vlans and servers will be left as it is.
12-31-2013 05:33 PM
See this below:
Network: 192.168.0.0/16
Broadcast: 192.168.255.255
HostMin: 192.168.0.1
HostMax: 192.168.255.254
Hosts/Net: 65534
With this as you see you will have 65534 addresses available to assign. Normally you can use 192.168.0.1 for the gateway address and the rest can be assign for the hosts that you have on your network, excluding the network and broadcast addresses.
Hope this helps.
12-31-2013 07:44 PM
Leo
Your response would be quite appropriate if you read the first line of the original post and then composed your response without reading further. But if you read further and especially when you get to this line
then it becomes very evident that treating it as a single network space /16 is not the appropriate response.
Lee
I am not clear where you are going with this statement
Do i need to basically add 1 on to each so staff is 251 hosts. As I think about how you ask the question I wonder if this is an attempt to include/add an address for the gateway for each vlan.
But if you think carefully and clearly about the situation that you describe it becomes a series of questions about classical subnetting:
- if Staff needs 250 hosts then what subnet is large enough (but not larger) to fit 250 hosts? answer is /24. (with 254 usable host addresses)
- if Support needs 30 hosts then what subnet is large enough (but not larger) to fit 30 hosts? answer is /27. (with 30 usable host addresses) But if we also need to allow an address for the gateway (if there really are 30 Support hosts) the the address requirement becomes 31 and the subnet becomes a /26 (with 62 host addresses)
- if Admin needs 8 hosts then what subnet is large enough(but not larger) to fit 8 hosts? answer is /28. (with 14 usable host addresses) note that this may be a bit tricky since a /29 actually has 8 addresses but if you reserve an address for the subnet and an address for the broadcast then it is no longer large enough for 8 hosts.
- if Server needs 5 hosts then what subnet is large enough (but not larger) to fit 5 hosts? answer is /29. (with 6 usable host addresses)
- if HR needs 50 hosts then what subnet is large enough (but not larger) to fit 50 hosts? answer is /26. (with 62 usable hosts addresses)
Rick
01-01-2014 03:49 AM
Lee
Rick has done a good job of showing how you break down the 192.168.0.0/16 to meet your needs.
In answer to your specific question in terrms of a gateway IP, yes each vlan/IP subnet will need some addresses reserved for the actual networking equipment. A common setup is to use something like HSRP for redundancy and if this is the case then you need to reserve the number of L3 devices + an extra IP for the virtual IP eg.
If ,for example, you have 2 L3 switches/routers for inter vlan routing and you were running HSRP between them you would need a total of 3 IP addresses one for each device and one for the virtual IP.
Jon
