Community Member
Does cisco Product have switch that support SFP 12 port or 24 port?
Dear All,
I want to ask you about Cisco switch that have module fireber 12 port or 24 port?
Best Regards,
Rechard
1 ACCEPTED SOLUTION
Re: Does cisco Product have switch that support SFP 12 port or 2
Hello Rechard,
The Catalyst 3750 series has three models with 12 SFP slots:
http://www.cisco.com/en/US/products/hw/switches/ps5023/prod_models_comparison.html
See in particular the models WS-C3750G-12S-S, WS-C3750G-12S-E, and WS-C3750G-12S-SD. For higher Catalyst series (4500, 6500), you would need to look up a particular line card.
Best regards,
Peter
Hello Rechard,
Best regards,
Peter
Hall of Fame Super Gold
As what Peter posted, the 3750G-12S is the most popular 12-port SFP.  If you need more, just get another one and stack them together.  However, if you want a single unit 24-port then the next model would be the WS-C3560E-12D.  This model has 12 ports of 10Gb but if you get TwinGig modules it will turn 12 x 10Gb into 24 x 1Gb.
677
