does ibgp run on vrf does a next hop modification?
Hi all,
As i understand when we run nomral bgp with 3 routers R1, R2 and R3 where R1 and R2 are running ebgp and R2 and R3 is running ibgp and a network advertized N1 by R1. N1 is R3 must see the advertized network with a next hop of R1's interface which basically signifies that ibgp does not do a next hop modification. This works absolutely fine when there are no vrf's configured. But if the same setup is configured as VRF ie R1 and R2 run ebgp in vrf outside and R2 and R3 run ibgp on outside vrf. We advertize N1 from R1. If we look at the bgp table on R3 we see the next hop to be R2 (which is strange because as per the standards ibgp does not do the next hop modification). i have attached the diagram and the configurations below. Can you please let me know what makes vrf ibgp neighbor to change the nexthop to self?
The configurations are as below
R1:
interface Ethernet0/0
ip vrf forwarding outside
ip address 155.1.0.1 255.255.255.0
router bgp 1
no synchronization
bgp log-neighbor-changes
network 0.0.0.0
no auto-summary
address-family ipv4 vrf outside
  neighbor 155.1.0.2 remote-as 65501
  neighbor 155.1.0.2 activate
  no synchronization
  network 0.0.0.0
exit-address-family
R2:
ip address 155.1.0.2 255.255.255.0
interface Ethernet0/1
ip address 155.1.1.2 255.255.255.0
router bgp 65501
  neighbor 155.1.0.1 remote-as 1
  neighbor 155.1.0.1 activate
  neighbor 155.1.1.3 remote-as 65501
  neighbor 155.1.1.3 activate
  no synchronization
exit-address-family
R3:
ip address 155.1.1.3 255.255.255.0
router bgp 65501
  neighbor 155.1.1.2 remote-as 65501
  neighbor 155.1.1.2 activate
  no synchronization
  network 3.3.3.0 mask 255.255.255.0
exit-address-family
BGP routes on R3
R3#sh ip bgp vpnv4 vrf outside neighbors 155.1.1.2 routes
BGP table version is 4, local router ID is 155.1.1.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 65501:23 (default for vrf outside)
*>i0.0.0.0          155.1.1.2                0    100      0 1 i
                        (R2)
Total number of prefixes 1
1 ACCEPTED SOLUTION
Hello there,
what you see is the expected behavior for iBGP implementations with VRF.
These types of sessions have an inherent next-hop-self (like eBGP sessions) unlike standard iBGP sessions in global table.
The idea is to make sure that connectivity from router receiving the prefix (the one after the CE, in your case R3) and the VPNV4 routes behind the PE (R1 for you) is preserved without the need of an IGP protocol between R2 and R3.
Don't forget that the eBGP session between PE and CE is a session which is traditionally run by an ISP which is normally a different administration entity from the one managing the routing from CEs and routers beyond this point. iBGP was not even considered as the right protocol to advertise the prefixes downstream. That is why the behavior is slightly different.
The only way to change the behavior and get the 'standard' one is by the use of a route map with set next-hop-unchanged.
hope it clarifies
please rate and close question if helpful
regards,
Riccardo
1 REPLY
Hello there,
hope it clarifies
regards,
Riccardo
1350
