09-02-2010 08:01 PM - edited 03-06-2019 12:48 PM
Hi Guys,
I have a 6500 running CatOS 8.4. On this device I have a ether channel group with 4 ports assigned to it. Only 2 of the ports are in use. I wish to reuse the unused ports but before I can do so I need to remove them from the group. If I do this using the set port channel mod/port mode off command, will this affect the active ports/ether channel?
TIA
Rgds
Scott
Solved! Go to Solution.
09-02-2010 09:13 PM
Generally, removing a port from the port channel should not affect the
overall operation of the etherchannel. You could first physically disconnect
the port (thereby forcing the switch to load balance the traffic between the
remaining interfaces) and then remove the interface from the channel group.
Hope this helps.
NT
09-02-2010 09:13 PM
Hope this helps.
NT
09-02-2010 11:45 PM
Thanks Nagaraja.
It worked just as you said. No impact on the port channel.
Rgds
Scott
