Does Router verify each & every packet while URL FILTERING is enabled?
i have enabled url filtering for 2 domains for denying access & rest are permitted, so does it mean that when ever even a permit host packets is also verified by the router & will the router take some process time for that verification & get over burden?
Re: Does Router verify each & every packet while URL FILTERING i
Hi Anand,
It depends on how you have configured the router for the inspection. If you are matching all the subnets you have then it will do it on all the traffic. You can configure it for Per user, IP segment using access-list.
-amit singh
Thanks for the reply, well the following are the config i have mentioned in the router & it works fine & suggest me what i need to apply more on this.
ip inspect alert-off
ip inspect name URL_FILTER http java-list 2 urlfilter
ip urlfilter allow-mode on
ip urlfilter cache 5
ip urlfilter exclusive-domain deny chatenabled.mail.google.com
ip urlfilter exclusive-domain deny .meebo.com
interface fastethernet 0/0
ip addres x.x.x.x
ip inspect URL_FILTER in
access-list 2 permit any
ip addres x.x.x.x
228
