10-14-2010 05:00 PM - edited 03-06-2019 01:32 PM
We have a switch 4503 with a supervizor Supervisor II+ 1000BaseX (GBIC)
The IOS installed is: cat4500-ipbase-mz.122-54.SG.bin.
With this IOS the command: ip polyce route-map can not be configured at itn vlan 1 or any other.
Can you tell us if the IOS: cat4000-i9s-mz.122-25.EWA14 does support this command: ip polyce route-map at any vlan?
Can you suggest any other IOS ?
Thanking you in advance.
Solved! Go to Solution.
10-15-2010 02:46 AM
The Supervisor II+ only supports basic L3 services eg. RIP/EIGRP stub. It does not support advanced IP services and to have PBR functionality you need advanced IP services. So unfortunately there is no IOS you can load onto this supervisor to make it work.
Jon
10-15-2010 02:46 AM
Jon
