Community Member
Does switch can change the default MTU on a port?
I saw there is a command change the switch whole system MTU, but does it allow only change the default MUT on a specific port?
THanks
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Does switch can change the default MTU on a port?
Rico
Whether or not you can change the mtu per interface depends on the switch model. See attached link for details -
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
Jon
1 REPLY
Rico
Jon
342
