Webcast-Catalyst9k
Does WS-X4013 Sup support WS-X4424-GB-RJ45 in 4003 chassis?
for an small test environment we plan to use a 4003 chassis with a Sup2 and a WS-X4424-GB-RJ45 line card.
Does anybody know if this is supported?
Best Regards,
Thorsten Steffen
1 ACCEPTED SOLUTION
Re: Does WS-X4013 Sup support WS-X4424-GB-RJ45 in 4003 chassis?
Yes, it is supported. You need a minimum of 6.3(1) Cat OS on Sup engine II.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/release/note/OL_4502.html
HTH,
-amit singh
1 REPLY
HTH,
-amit singh
230
