Dose Cisco 3850 support PBR with Tracking?
horance
Configured PBR in Cisco 3850 ,But i can't find policy route map in my interface.
route-map test1 permit 10
match ip address PBR_server
set ip next-hop verify-availability 10.3.2.1 1 track 1
Core_IDC3850#sh track
Track 1
  IP SLA 1 state
  State is Up
    10 changes, last change 00:01:16
  Latest operation return code: OK
  Latest RTT (millisecs) 1
  Tracked by:
    ROUTE-MAP 0
show route-map
route-map test1, permit, sequence 10
  Match clauses:
    ip address (access-lists): PBR_server
  Set clauses:
    ip next-hop verify-availability 10.3.2.1 1 track 1  [up]
Core_IDC3850#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Core_IDC3850(config)#int vlan 2
Core_IDC3850(config-if)#ip poli
Core_IDC3850(config-if)#ip policy rou
Core_IDC3850(config-if)#ip policy route-map test1
Core_IDC3850(config-if)#exit
Core_IDC3850(config)#do sh run int vlan2
Building configuration...
Current configuration : 60 bytes
interface Vlan2
ip address 172.16.1.1 255.255.255.0
end
My switch ver.
Switch Ports Model              SW Version        SW Image              Mode
*    1 32    WS-C3850-24T       03.03.01SE        cat3k_caa-universalk9 INSTALL
cadet alain
Have you changed your SDM template ? I think you need Advanced template for PBR  and which licence have you got installed( you need IPBase) ?
Alain
Hi Alain,
  My C3850 SDM prefer advance and licence is ip service.
If i remove verify-availability  the PBR running correct.
Core_IDC3850#sh sdm prefer
Showing SDM Template Info
This is the Advanced (high scale) template.
  Number of VLANs:                                 4094
  Unicast MAC addresses:                           32768
  Overflow Unicast MAC addresses:                  512
  IGMP and Multicast groups:                       8192
  Overflow IGMP and Multicast groups:              512
  Directly connected routes:                       32768
  Indirect routes:                                 7680
  Security Access Control Entries:                 3072
  QoS Access Control Entries:                      3072
  Policy Based Routing ACEs:                       1024
  Netflow ACEs:                                    1024
  Input Microflow policer ACEs:                    256
  Output Microflow policer ACEs:                   256
  Flow SPAN ACEs:                                  256
  Tunnels:                                         256
  Control Plane Entries:                           512
  Input Netflow flows:                             8192
  Output Netflow flows:                            16384
  SGT/DGT entries:                                 4096
  SGT/DGT Overflow entries:                        512
These numbers are typical for L2 and IPv4 features.
Some features such as IPv6, use up double the entry size;
so only half as many entries can be created.
Core_IDC3850#sh license right-to-use
Slot#  License name   Type     Count   Period left
1      ipservices   permanent     N/A   Lifetime
set ip next-hop 10.3.2.1
Core_IDC3850#                  conf t
Core_IDC3850(config-if)#^Z
Core_IDC3850#sh run int vlan 2
Current configuration : 87 bytes
interface Vlan2
end
Core_IDC3850#
Horace
check my other post for answer
https://supportforums.cisco.com/discussion/12357181/route-map-not-taken-3850-ip-services#comment-10091941
