dot1q not working between ap1131 and asa5505
I try to configure a asa5505 and a AIR-AP1131 to communicate over a trunk (Guest VLAN). A PC connected to the ASA / Vlan3-Port is able to communicate and is able to get an ip address via DHCP from DHCP-server for VLAN3 an the ASA . The AP is connected with a trunk port of the ASA. Connecting wireless to the AP no communication is possible. Trying DHCP und debugging these behavior on the ASA shows incoming DHCP requests and offers. The offers do not arrive at the wireless PC.Do anyone see in the attached configuration files what is the mistake ? Thank you for help.
Re: dot1q not working between ap1131 and asa5505
Additioal here is the dhcpd-debug of the asa. I don't know, why the mac address is shown with a length of 7 bytes.
Why do you have the trunk set up just to allow VLAN 3? If you are going to do that set both ports to Acees and see if you get the request.
The other thing is to create bvi 4 and assign an IP adress to it on the AP based on vlan 3 IP adresses.
Purple
On the ASA it appears that you do not have anything setup for vlan 1 . You are only allowing vlan 3 across the trunk and vlan 1 is the native on the ap . Change the ASA to look like the following also get rid of the 100/half duplex setting . Also on the ap make sure you have your default gateway set to 192.168.100.1 .
interface Ethernet0/5
switchport encapsulation dot1q
switchport trunk allowed vlan 1,3
switchport trunk native vlan 1
switchport mode trunk
speed auto
duplex auto
285
