Community Member
Dot1q tag not appear on SPAN destination port on 6513
When a dot1q trunk is SPANd on a 6513 the dot1q tag appears to be lost. This is supported on the 3750s I have in a lab but not the 6513. Any ideas?
Leigh
Re: Dot1q tag not appear on SPAN destination port on 6513
Hi Leigh,
You need to configure the destination port as trunk, setting is to non-negotiate and the chosen encapsulation type.
Then, configure the monitor session to use it as destination port.
Note that the sequence here is important. You have to configure destination port first and then configure the SPAN session, a restriction removed in some latest releases. There is no need to specify the encapsulation type in SPAN session configuration in 6500, as for 3750. Please try it out and update if it works for you.
Ankur
*Pls rate all helpfull post
Community Member
Thanks that is it
That does the trick. Just a note when changing to non-negotiate the port need a shut/no shut before it works
322
