Dot1q trunk between 6500 and 4948 issues
I'm having some trouble with establishing a trunk port between a Cisco 6513 and Cisco 4948.
Here is the config:
Cisco 6513
int gig 8/1
switchport
switchport encap dot1q
switchport mode trunk
switchport trunk allowed vlan 1
speed noneg
no shut
int vlan 1
description Mgmt VLAN
ip address 10.10.10.1 255.255.255.0
no shut
Cisco 4948
gig 1/48
switchport
speed noneg
no shut
int vlan 1
ip address  10.10.10.2 255.255.255.0
no shut
Status:
1- Both Gige's are up/up
2- But can't ping each other
Cards on Cisco 6513:
  slot:7    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
  Slot:8    2  Supervisor Engine 720 (Hot)            WS-SUP720-3B
I have Gig7/1 on Cisco 6513 and Gi1/47 on the Cisco 4948 up, as a routed port.  I hate to touch these ports or else I loose connectivity to the Cisco 4948.
-Manny
Re: Dot1q trunk between 6500 and 4948 issues
Manny,
Can you provide from both 6513 and 4948 switches the  output of  " show int gig8/1  switchport " and "show int gig1/48  switchport" , also output of "show interface gig8/1 trunk" ,  show int gig1/48 trunk  from the 4948 .
you may need to   use " switchport  trunk encap dot1q"  in the interfaces  , unless switchport encap dot1q  syntax is a typo or command was introduce in a ios version Im not aware of then is fine,  but  the output  of above interface information  as well as "show vtp status" from each switch would help to understand your l2 topology and  give us some hints on what could be the issue on the interfaces
Can I ask you something ? Isnt is that the port are working as switchports ( trunk mode ) and you are assigning Ip address on that switchport and trying to ping them. I think ones the port is in switching mode the ip address is assigned to the SVI and then you can access the switch using that SVI ip address. It is always the routed port that are assigned the ip address.
Let me know if my understanding of switchports and routed ports are wrong !! plz
Manish
sorry ! misread it the first time , drunk i believe ... did not see the interface vlan config. can you post
1> sh ip route
2> sh spanning tree
3> Vlan database
Manish
Cisco 4948-
sho run int gig 1/47
interface GigabitEthernet1/47
description to Cisco 6515 – Gi7/1
ip address 20.20.20.1 255.255.255.252
speed nonegotiate
end
show run int gig 1/48
interface GigabitEthernet1/48
description to Cisco 6515   -  Gi8/1
switchport trunk encapsulation   dot1q
shutdown
speed nonegotiate
end
show int gig 1/48
GigabitEthernet1/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet   Port, address is 001a.6d2e.25ef (bia 001a.6d2e.25ef)
  MTU 1500 bytes, BW 1000000   Kbit, DLY 10 usec,
     reliability 255/255, txload   1/255, rxload 1/255
  Encapsulation ARPA, loopback   not set
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link   type is force-up, media type is 1000BaseLH
  Media-type configured as SFP   connector
  input flow-control is on,   output flow-control is off
  ARP type: ARPA, ARP Timeout   04:00:00
  Last input 00:00:00, output   never, output hang never
  Last clearing of "show   interface" counters never
  Input queue: 0/2000/0/0   (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 7000   bits/sec, 7 packets/sec
  5 minute output rate 0   bits/sec, 0 packets/sec
     52743 packets input,   4514048 bytes, 0 no buffer
     Received 50864 broadcasts   (19152 multicast)
     0 runts, 0 giants, 0   throttles
     0 input errors, 0 CRC, 0   frame, 0 overrun, 0 ignored
     0 input packets with   dribble condition detected
     384 packets output, 62066   bytes, 0 underruns
     0 output errors, 0   collisions, 0 interface resets
     0 babbles, 0 late   collision, 0 deferred
     0 lost carrier, 0 no   carrier
     0 output buffer failures, 0   output buffers swapped out
show run int vlan 1
interface Vlan1
ip address 172.22.100.28   255.255.255.0
end
ping 172.22.100.23
Sending 5, 100-byte ICMP Echos to 172.22.100.23, timeout is 2 seconds:
Success rate is 0 percent (0/5)
show ip ro
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP   external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external   type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type   1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, su - IS-IS   summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, *   - candidate default, U - per-user static route
       o - ODR, P - periodic   downloaded static route
Gateway of last resort is 172.22.100.1 to network 0.0.0.0
     20.0.0.0/30 is subnetted, 1   subnets
C       20.20.20.0 is directly   connected, GigabitEthernet1/47
     172.22.0.0/24 is subnetted,   1 subnets
C       172.22.100.0 is directly   connected, Vlan1
S*   0.0.0.0/0 [1/0] via   172.22.100.1
show spanning-tree
VLAN0001
  Spanning tree enabled protocol   ieee
  Root ID    Priority    32768
             Address     0006.282b.7680
             Cost        23
             Port        48 (GigabitEthernet1/48)
             Hello Time   2 sec  Max Age 20 sec Forward Delay 15   sec
  Bridge ID  Priority    32769  (priority 32768   sys-id-ext 1)
             Address     001a.6d2e.25c0
             Aging Time 300
Interface        Role Sts   Cost      Prio.Nbr Type
Gi1/48           Root FWD 4         128.48   P2p
show int vlan 1
Vlan1 is up, line protocol is up
  Hardware is Ethernet SVI, address   is 001a.6d2e.25ff (bia 001a.6d2e.25ff)
  Internet address is   172.22.100.28/24
  Last input 00:00:07, output   never, output hang never
  Input queue: 0/75/0/0   (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 0   bits/sec, 0 packets/sec
  L3 in Switched: ucast: 0 pkt,   0 bytes - mcast: 0 pkt, 0 bytes
  L3 out Switched: ucast: 0 pkt,   0 bytes - mcast: 0 pkt, 0 bytes
     639 packets input, 260024   bytes, 0 no buffer
     Received 639 broadcasts (0   IP multicast)
     120 packets output, 6330   bytes, 0 underruns
     0 output errors, 0   interface resets
show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route   Bridge
                  S - Switch, H   - Host, I - IGMP, r - Repeater, P - Phone
Device ID            Local Intrfce         Holdtme   Capability    Platform   Port ID
Cisco 6515     Gig 1/48              130           R S I     WS-C6513  Gig 8/1
Cisco 6515     Gig 1/47              161           R S I     WS-C6513  Gig 7/1
Cisco 6515-
show run int gig 8/1
interface GigabitEthernet8/1
description to Cisco 4948 -   Gi1/48
switchport
speed nonegotiate
end
show run int gig 7/1
interface GigabitEthernet7/1
description to Cisco 4948 -   Gi1/47
ip address 20.20.20.2   255.255.255.252
speed nonegotiate
show int gig 8/1
GigabitEthernet8/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3,   address is 0013.7f0d.3ce4 (bia 0013.7f0d.3ce4)
  Full-duplex, 1000Mb/s, media   type is LH
  input flow-control is off,   output flow-control is on
  Clock mode is auto
  Last input 3d22h, output   00:00:07, output hang never
  Last clearing of "show   interface" counters 29w5d
     555 packets input, 89894   bytes, 0 no buffer
     Received 505 broadcasts   (500 multicasts)
     0 watchdog, 0 multicast, 0   pause input
     52504 packets output,   4595486 bytes, 0 underruns
     0 output errors, 0   collisions, 3 interface resets
     0 lost carrier, 0 no   carrier, 0 PAUSE output
show run int vlan 1
interface Vlan1
ip address 172.22.100.23   255.255.255.0
end
ping 172.22.100.28
Sending 5, 100-byte ICMP Echos to 172.22.100.28, timeout is 2 seconds:
show ip route
C       20.20.20.0 is directly   connected, GigabitEthernet7/1
show spanning-tree
VLAN0001
             Cost        19
             Port        176 (FastEthernet2/48)
             Address     000b.60f3.ab80
             Aging Time 300
Fa2/48              Root FWD 19        128.176  P2p
Gi4/3               Desg FWD   4         128.387  P2p
Gi8/1               Desg FWD   4         128.897  P2p
Po4                 Desg FWD   4         128.1665 P2p
Po5                 Desg FWD   4         128.1666 P2p
show cdp neighbors
Cisco 4948 Gig 8/1           179          R S I     WS-C4948  Gig 1/48
Cisco 4948 Gig 7/1           167          R S I     WS-C4948  Gig 1/47
show int vlan 1
  Hardware is EtherSVI, address   is 000b.60f3.ab80 (bia 000b.60f3.ab80)
  Internet address is   172.22.100.23/24
  Keepalive not supported
  Last input 00:00:00, output   00:00:00, output hang never
  Input queue: 0/75/751936/0   (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 2000   bits/sec, 4 packets/sec
  5 minute output rate 3000   bits/sec, 3 packets/sec
  L2 Switched: ucast: 1679904971   pkt, 1055602240049 bytes - mcast: 40919877 pkt, 3222830684 bytes
  L3 in Switched: ucast: 0 pkt,   0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 26171 pkt, 2162109   bytes mcast: 0 pkt, 0 bytes
     40688097 packets input,   3317459000 bytes, 0 no buffer
     Received 40170596   broadcasts (29217 IP multicasts)
     0 runts, 0 giants, 3352   throttles
     532795 packets output,   158199679 bytes, 0 underruns
Fiber
Something is not right.  The 'sh run' shows interface g1/48 as 'shutdown', but the 'sh int g1/48' shows it up/up.
Can you verify that it isn't shutdown.
Can you also post the 'show interface trunk' output ?
I dont have much experience with the Cisco 6515, can Gig8/1 on the Cisco 6515 be on-standby since its the standy card?  Card in slot 7 is active.  I figured Gig8/1 can not be used, but I maybe wrong.
Cisco   4948
ping 172.22.100.23
show int gig 1/47
GigabitEthernet1/47 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet   Port, address is 001a.6d2e.25ff (bia 001a.6d2e.25ff)
  Description: to Cisco 6515 - Gi7/1
  Internet address is   20.20.20.1/30
  5 minute output rate 1000   bits/sec, 1 packets/sec
  L3 in Switched: ucast: 2224   pkt, 92157 bytes - mcast: 0 pkt, 0 bytes
     213212 packets input,   20240692 bytes, 0 no buffer
     Received 207575 broadcasts   (0 IP multicast)
     13762 packets output,   4526996 bytes, 0 underruns
show int gig 1/48
  Description: to Cisco 6515 -   Gi8/1
  5 minute input rate 18000   bits/sec, 21 packets/sec
     70401 packets input,   5868701 bytes, 0 no buffer
     Received 67842 broadcasts   (32571 multicast)
     430 packets output, 67334   bytes, 0 underruns
show int trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi1/48      on           802.1q         trunking      1
Port        Vlans allowed on   trunk
Gi1/48      1-4094
Port        Vlans allowed and   active in management domain
Gi1/48      1
Port        Vlans in spanning   tree forwarding state and not pruned
Gi1/48      1
Cisco   6515
ping 172.22.100.28
show int gig 7/1
GigabitEthernet7/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3,   address is 000b.60f3.ab80 (bia 000b.60f3.ab80)
  Description: to Cisco 4948 -   Gi1/47
  Internet address is   20.20.20.2/30
  Clock mode is auto
  Last input 00:00:20, output   00:00:20, output hang never
  L2 Switched: ucast: 1886 pkt,   181338 bytes - mcast: 5 pkt, 335 bytes
  L3 out Switched: ucast: 0 pkt,   0 bytes mcast: 0 pkt, 0 bytes
     14198 packets input,   4577862 bytes, 0 no buffer
     Received 12121 broadcasts   (0 IP multicasts)
     223015 packets output,   21303395 bytes, 0 underruns
     0 output errors, 0   collisions, 5 interface resets
show int gig 8/1
  Description: to Cisco 4948 -   Gi1/48
  Clock mode is auto
  Last input 00:00:42, output   00:00:44, output hang never
  5 minute output rate 17000   bits/sec, 20 packets/sec
     606 packets input, 95814   bytes, 0 no buffer
     Received 534 broadcasts   (529 multicasts)
     72853 packets output,   6150090 bytes, 0 underruns
show int trunk
Gi4/3               on           802.1q         trunking      1
Gi8/1               on           802.1q         trunking      1
Po4                 on           802.1q         trunking      1
Po5                 on           802.1q         trunking      1
Gi4/3               1,328-348
Gi8/1               1-4094
Po4                 1,300-499,600-699
Po5                 1,300-499,600-699
Gi4/3               1,328-348
Gi8/1               1,149,301-349,401-406
Po4                 1,301-349,401-406
Po5                 1,301-349,401-406
Gi4/3               1,328-348
2133
