Bronze
dot1q trunk
hi everybody!
Does dot1q not support pvst?
cisco switches by default operates in pvst mode. So how can dotq trunk appears to support pvst?
thanks a lot!
Blue
Re: dot1q trunk
dot1q is perfectly compatible with pvst STP standard.
Not sure I understand what you're asking...
Bronze
Re: dot1q trunk
thanks for your reply. I just found out it was pvst+ not pvst that support dot1q.cisco switches by default operate pvst+ so that explain why dot1q tunnel works between switches.
145
