DOT1X Authentication erros Switch 3750
We have configured dot1x authentication in our network, but we are seeing constantly logs errors in all 3750 switches, the 3550 and 3560 are working well.
The logas are the next_:
Aug 28 08:32:16: %DOT1X-5-FAIL: Authentication failed for client (Unknown MAC) on Interface Fa1/0/42
Aug 28 08:32:16: %AUTHMGR-5-FAIL: Authorization failed for client (Unknown MAC) on Interface Fa1/0/42
Aug 28 08:34:49: %DOT1X-5-FAIL: Authentication failed for client (Unknown MAC) on Interface Fa1/0/42
Aug 28 08:34:49: %AUTHMGR-5-FAIL: Authorization failed for client (Unknown MAC) on Interface Fa1/0/42
It always says Unknown mac, but it is happening in all ports and I look other 3750 switches and I saw the same behavior. This behavior is causing problems to the users, and they cannot access to the network.
The configuration of the port is:
interface FastEthernet1/0/42
switchport access vlan 6
switchport mode access
switchport voice vlan 205
srr-queue bandwidth share 1 75 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
authentication port-control auto
authentication periodic
authentication timer reauthenticate 10800
authentication violation protect
mls qos trust device cisco-phone
mls qos trust cos
dot1x pae authenticator
dot1x timeout quiet-period 5
spanning-tree portfast
service-policy input mark
And int the switch:
SW3750_ADMBOGCITIBANK_5F#sh run | i dot1x
aaa authentication dot1x default group radius none
dot1x system-auth-control
dot1x guest-vlan supplicant
SW3750_ADMBOGCITIBANK_5F#sh run | i radius
aaa authorization network default group radius none
radius-server dead-criteria tries 3
radius-server host 10.69.36.35 auth-port 1812 acct-port 1813 key 7 080243420614071E13260312232776
radius-server host 10.69.52.25 auth-port 1812 acct-port 1813 key 7 052809032E414C0018281804020056
radius-server deadtime 2
Thanks for your attention, and I hope somebody can help us.
217
