dot1x , Cisco ACS and AD problem in password changes
HI, i configured 802.1X authentication with Cisco Secure ACS 4.2 that is sync with Active Directory , everything is ok except that when i change password of a user on AD, user still can login with the old password on the client PC while if he/she use a different workstation can login with new password. it seems it put old pass in local PC cash...
thanks,
Saeed Zamani
Re: dot1x , Cisco ACS and AD problem in password changes
I think this is because credentials are cached. To test the theory
1) Wait for a while arbitrary interval say > 10 minutes and retry. It should fail if you try to use the old credentials.
2) Reboot switch. Retry it should not allow.
no , i checked everything , user can login with the new password on other machines, i think it is because that machine is in un-athenticated mode , if a new user or administrator login on that machine then that user can also login with new password.
Rgrds,
Saeed.
259
