Dear expert,
I am testing the the dot1x feature and get the below result. I feel point 4 is not quite make sense.
Can I make that for dot1x client, Even they haven't enter their username and password, they also will
not be assigned to guest vlan ( vlan 99)
interface FastEthernet0/24
switchport mode access
dot1x pae authenticator
dot1x port-control auto
dot1x violation-mode protect
dot1x guest-vlan 99
dot1x auth-fail vlan 999
spanning-tree portfast
1) wait 30 sec for username prompt
2) For three times password verify fail, port 24 will cange to vlan 999
3) For dot1x non compatible client, wait 1 min 30 sec, port will change to vlan 99
4) For dot1x client, If connect to port 24 but not login, wait 1 min 30 sec, port will change to vlan 99
