03-13-2007 01:00 PM - edited 03-05-2019 02:53 PM
Does anybody know, any good how to to implement
that integration ?
cisco 2950 X IAS x PEAP
obs : On wired network
Solved! Go to Solution.
03-14-2007 12:55 PM
something like this...
03-13-2007 01:05 PM
Here's the microsoft doc...
03-13-2007 03:14 PM
thanks acomiskey,
I setup the work with success
but i have a problem to solve...
The client authenticated, but is nothing getting IP address from dhcp server, because the dhcp server is in another vlan and is another network range . follow settings:
dhcp server and ias server (w2k3):
vlan : 10
ip : 192.168.10.100 / 24
client pc (wxp) (after authenticated)
vlan : 20
ip range : 192.168.20.0 /24
guest vlan : 30
what would i do to get dynamic ip from DHCP ?
does have a dhcp server in same vlan and address range of client pc ?
Att Antonio
03-13-2007 05:21 PM
config t
interface vlan 20
ip helper-address 192.168.10.100
exit
interface vlan 30
Set up the pools on your dhcp server and you're good to go. Please rate these if they helped.
03-14-2007 07:34 AM
Is it working now?
03-14-2007 08:23 AM
acomiskey,
i included this instructions, but didn't solve the problem...
what can be occurring ?
follow sh rum command attached on post..
obs :
fe 0/9 - my w2k3 server (ad server + ias server + dhcp server)
fe 0/17 - my client pc wXP
fe 0/10 - is a trunk to a linux server, that it's making routing vlan's using.
att
Antonio
03-14-2007 08:57 AM
Your vlan's appear to be "shutdown".
03-14-2007 09:05 AM
so,
if i set
int vlan 20
no shut
..........vlan 10 that is my up vlan and that a i use to manager the switch goes down !
and after
int vlan 30
no shut
....vlan 20 goes down...
so, the switch 2950 only permit that i have ONE vlan on up state....
Att
Antonio
03-14-2007 09:13 AM
Hmm, you can have multiple vlans active on the switch, but you cannot have multiple vlan interface active at the same time.
03-14-2007 10:34 AM
Yes,
do you have any idea to solve this ?
03-14-2007 10:59 AM
Are you routing between vlans and if so where? I've never done this on a layer 2 switch, but what's happening is typical of a layer 2 switch. You can only have 1 vlan int active at a time. Where is the default gateway for vlan 20 and 30? We may need someone else's help here.
03-14-2007 11:38 AM
Also, what is this linux server you mentioned?
03-14-2007 12:50 PM
It's a ubuntu linux, loading a package (modeprobe and 8021q) to routing vlan's.
03-14-2007 12:55 PM
03-14-2007 02:26 PM
acomiskey,
it's working now !!!
i installed the dhcp3-relay package on ubuntu
thanks so much....
Antonio
