dot1x : IAS x PEAP X 2950 ????
Does anybody know, any good how to to implement
that integration ?
cisco 2950 X IAS x PEAP
obs : On wired network
1 ACCEPTED SOLUTION
Green
Re: dot1x : IAS x PEAP X 2950 ????
Green
thanks acomiskey,
I setup the work with success
but i have a problem to solve...
The client authenticated, but is nothing getting IP address from dhcp server, because the dhcp server is in another vlan and is another network range . follow settings:
dhcp server and ias server (w2k3):
vlan : 10
ip : 192.168.10.100 / 24
client pc (wxp) (after authenticated)
vlan : 20
ip range : 192.168.20.0 /24
guest vlan : 30
what would i do to get dynamic ip from DHCP ?
does have a dhcp server in same vlan and address range of client pc ?
Att Antonio
Green
config t
interface vlan 20
ip helper-address 192.168.10.100
exit
interface vlan 30
Set up the pools on your dhcp server and you're good to go. Please rate these if they helped.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00800d7668.html#xtocid9
Green
Is it working now?
acomiskey,
i included this instructions, but didn't solve the problem...
what can be occurring ?
follow sh rum command attached on post..
obs :
fe 0/9 - my w2k3 server (ad server + ias server + dhcp server)
fe 0/17 - my client pc wXP
fe 0/10 - is a trunk to a linux server, that it's making routing vlan's using.
att
Antonio
Green
Your vlan's appear to be "shutdown".
so,
if i set
int vlan 20
no shut
..........vlan 10 that is my up vlan and that a i use to manager the switch goes down !
and after
int vlan 30
no shut
....vlan 20 goes down...
so, the switch 2950 only permit that i have ONE vlan on up state....
Att
Antonio
Green
Hmm, you can have multiple vlans active on the switch, but you cannot have multiple vlan interface active at the same time.
Yes,
do you have any idea to solve this ?
Green
Are you routing between vlans and if so where? I've never done this on a layer 2 switch, but what's happening is typical of a layer 2 switch. You can only have 1 vlan int active at a time. Where is the default gateway for vlan 20 and 30? We may need someone else's help here.
Green
Also, what is this linux server you mentioned?
It's a ubuntu linux, loading a package (modeprobe and 8021q) to routing vlan's.
Green
acomiskey,
it's working now !!!
i installed the dhcp3-relay package on ubuntu
thanks so much....
Antonio
Green
Good deal, that was fun!
260
