Dot1x inaccessible authentication bypass auth-fail problem with 4510R-E Sup 6-E 12.2(54)SG
We have a problem with Catalyst 4510R-E, Sup 6-E, IOS 12.2(54)SG (same issue repeats with IOS 12.2(53) SG3 as well) do1x authentication when RADIS server is inaccessible. Switch port simple doesn’t go into auth-failed vlan, but stays in access vlan 40.
Same configuration with 3750 switch and IOS 12.2(55)SE works.
Below is the configuration of the switch:
aaa group server radius dot1x
server-private 10.200.1.27 key 7 1
server-private 10.200.1.26 key 7 1
ip vrf forwarding data
ip radius source-interface Vlan100
aaa authentication dot1x default group dot1x
aaa authorization network default none
interface GigabitEthernet1/48
description TEST DOT1X
switchport access vlan 40
switchport mode access
authentication event server dead action authorize vlan 240
authentication event server alive action reinitialize
authentication port-control auto
dot1x pae authenticator
dot1x timeout server-timeout 10
dot1x timeout tx-period 10
dot1x timeout start-period 20
spanning-tree portfast
interface Vlan40
ip address 10.10.10.1 255.255.255.0
ip radius source-interface Vlan100 vrf data
radius-server dead-criteria time 3 tries 2
radius-server host 10.200.1.27 auth-port 1645 acct-port 1646 test username admin idle-time 1
radius-server host 10.200.1.26 auth-port 1645 acct-port 1646 test username admin idle-time 1
radius-server deadtime 3
dot1x system-auth-control
dot1x critical eapol
Does anyone have an idea what we could do to resolve this?
312
