Dot1x with Nortel VoIP
I've configured dot1x with using MS IAS as radius server. All seems to work fine when i connect a pc to a port configured for dot1x. But i face problem when my Nortel VoIP phones are involved.
Below are the list of problems with nortel ip phones connnected on a dot1x port:
All ports are configured for dot1x multi-host mode
1) whenver i enable a port for dot1x the phone goes down until i get authenticated from the laptop by putting the credentials
2)sometimes users into network without and get an IP address without putting the credentails. This only happens if i enable dot1x multi-host enable
is there a way that i can enable port without dot1x multi-host mode and get phones work with only dot1x port control auto command
AI
1 REPLY
Silver
Re: Dot1x with Nortel VoIP
To disable multiple hosts on the port, use the no dot1x host-mode multi-host interface configuration command.Refer URL for more
http://www.cisco.com/en/US/products/ps6748/products_configuration_guide_chapter09186a00805fe08d.html#wp1195426
231
