Community Member
Doubt about WS-X6148A-GE-TX Port-ASIC mapping
Can someone clarify what is the Port-Asic mapping in WS-X6148A-GE-TX.
In this document http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Module_Installation/Mod_Install_Guide/02ethern.html#wp1062961
says:
Port groups
WS-X6148A-GE-TX—6
Port ranges per port group
WS-X6148A-GE-TX: 1-8, 9-16, 17-24, 25-32, 33-40, 41-48
And with show interfaces capabilities module X, I see that there is one ASIC to 48 ports:
Copiapo_7604#show interfaces capabilities module 4
GigabitEthernet4/1
  Model:                 WS-X6148A-GE-TX
  Type:                  10/100/1000BaseT
  Speed:                 10,100,1000,auto
  Duplex:                half,full
  Trunk encap. type:     802.1Q,ISL
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: none
  Flowcontrol:           rx-(off,on,desired),tx-(off,on,desired)
  Membership:            static
  Fast Start:            yes
  QOS scheduling:        rx-(1q2t), tx-(1p3q8t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  SPAN:                  source/destination
  UDLD                   yes
  Link Debounce:         yes
  Link Debounce Time:    no
  Ports on ASIC:         1-48
  Port-Security:         yes
best regards,
Jaime Soto.
Hi Jaime,
It has onboard 6 ASICS with 8 front pannel ports connected to each ASIC. Not sure how to interpret the output above, I guess it says how many total ports are connected to ASICS and all 1-48 ports are connected to the ASICS on board.
Please see another link for the confirmation related to port distribution when configuring etherchannel on 6148 module.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml#cat6k
Cheers,
-amit singh
I believe that is referring to the Fabric ASICS for the module it self. If you did that for each module you would see the same thing. Try doing the command for an interface.
We had that line card and ran into issues when we had some very heavy traffic on the same ASICS. We kept seeing a lot of traffic issues. We split them up and it improved but that wasted a lot of ports. We upgraded to W-6748-GE-TX, that card has one ASICS per port.
Mike
The port groupings in sh int cap are from a qos configuration standpoint only, they are not meant to (necessarily) reflect the internal architecture.
As already pointed out there are 6 Port ASICs on this LC.
regards,
Riccardo
2042
