Community Member
Drop in LAN connection
Hi All,
I have a 2811 series router with a HWIC-4ESW installed in it along with a VWIC2-2MFTT1/E1 card. I have all of the interfaces on the ethernet hwic in vlan 1 and have assigned ip addresses to stations that are connected to these ports and also an ip to the vlan 1 int. everything seems to have been working fine for a few weeks, except this morning I noticed I could not get to any of the stations that resided on the ethernet ports. All of the ports said up up and vlan 1 was up and pinged. i could not ping the hosts and the hosts could not ping the GW(vlan 1 int). I reloaded the router and it all came back to life, any ideas as to what could have happened? I have the following config:
Current configuration : 2046 bytes
version 12.4
hostname
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 51200 warnings
no aaa new-model
resource policy
no network-clock-participate wic 0
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
username
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address <public ip1> 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1/0
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/0/0:1
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0/0/0:1.1 point-to-point
bandwidth 1536
ip unnumbered FastEthernet0/0
ip nat outside
frame-relay interface-dlci 500 IETF
interface Serial0/0/1:1
no ip address
interface Vlan1
ip nat inside
interface Vlan2
no ip address
interface Vlan3
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0:1.1
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static <private ip1> <public ip2>
ip nat inside source static <private ip2> <public ip3>
ip nat inside source static <private ip3> <public ip4>
access-list 101 permit ip any any
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Cola_VC#
TIA,
R
1 REPLY
Bronze
Re: Drop in LAN connection
I think this is normal behavior because we need to enable the packet driver if you do not reboot. If you do not reboot we AUTOMATICALLY enable the packet driver, which requires we disable and re-enable the NIC.
194
