08-29-2012 04:55 AM - edited 03-07-2019 08:35 AM
I have a remote site that is having performance trouble. I am able to PING the router and the core switch without issue. However, every time I ping another switch or computer on VLAN1 the ping test shows up like below:
Sending 100, 1000-byte ICMP Echos to xxx.xxx.xxx.xxx, timeout is 2 seconds:
Success rate is 96 percent (96/100), round-trip min/avg/max = 76/81/308 ms
This happens only with a device on VLAN1 and there is always atleast 4 if not 10 to 15 drops. If I PING a device on any other VLAN it reponds correctly and immediately.
I recently moved layer3 from our providor managed router to our core switch. No routing is being done on the LAN, only across the WAN. We have a 0.0.0.0 route pointing to the managed router in the core.
Any ideas what could be causing this?
08-29-2012 05:20 AM
Hi Josh,
you did not provide too many info but i would start to check if any mismatch native vlan is in place ...
conf t
logg buff 16000 debug
end
wr
this is to have a debug level of logs to see with
show logg
Alessio
08-29-2012 05:31 AM
Thank Alessio,
I have made the change to the logging. No log messages yet.
I can provide any information that would assist you.
Josh
08-29-2012 06:11 AM
What happens if you immediately re-run the ping command? Are there still dropped packets at the start?
08-29-2012 07:49 AM
Colin,
It responds as normal immediately following but as you can see from the results below there were more timeouts in the middle.
NUSOP3A1#ping ip xxx.xxx.xxx.xxx repeat 100 size 1000
Success rate is 77 percent (77/100), round-trip min/avg/max = 76/110/760 m
NUSOP3A1#
Success rate is 94 percent (94/100), round-trip min/avg/max = 76/81/108 ms
Josh
08-29-2012 08:08 AM
Josh,
Beyond pinging the end host, what troubleshooting steps have you taken so far?
Some examples:
can you see any interface errors?
have you performed a traceroute to the destination?
can you ping the next hop successfully? (assuming the address you are pinging is not your next hop )
can you ping the destination successfully from another host?
08-29-2012 08:54 AM
Colin,
Only one interface on the core is incrementing any errors. I have disabled that just as a test and it didn't affect anything.
I am able to trace from my laptop and my locations core switch to the remote sites devices. Always atleast 1 timeout each time.
This is the last hop so I can't ping any farther. I don't have any issues pinging from the remote site back to myself or anywhere else.
Regardless of location (we have many) pinging anything at this remote site on VLAN1 is the same.
Pings internally work, both from the router and from the core switch.
Josh
08-29-2012 12:07 PM
Side question....would these commands:
conf t
end
wr
Cause performance issues such as the command debug all?
08-30-2012 06:49 AM
Jimmy
No, the logg buff 16000 debug will not cause the same performance issues that the debug all command does.
See the warning from from Cisco below:
Caution Because debugging output takes priority over other network traffic, and because the debug all command generates more output than any other debug command, it can severely diminish switch performance or render the switch unusable. Use more specific debug commands. |
Josh
