05-26-2009 04:00 AM - edited 03-06-2019 05:55 AM
I am looking for an easy to implement method to prevent end users from using ip multicast applications. Does anybody know if it's possible to disallow incoming multicast packets on access ports?
Many thanks in advance,
Thorsten Steffen
05-26-2009 04:48 AM
Don't enable PIM and if you need to forward Multicast but not receive it use ACL blocking PIM INBOUND but permit IGMP.
You can also block Multicast IP addresses altogether
There are other methods with setting TTL on interfaces.
Sam
05-26-2009 06:12 AM
Hi Sam,
could you please tell me in detail the commands which I have to use for your different recommendations?
Thorsten
05-26-2009 07:48 AM
1-Disabling PIM is straight forward, if it is not unabled on layer 3 interface don't enable it.
do "show ip pim interface" to validate.
2-blocking PIM and permitting the rest :
access-list 101 deny pim any any
access-list 101 permit ip any any
under layer interface:
ip access-group 101 in
3-Blocking Multicast addresses (assuming you are not routing between your access and customers)
access-list 102 deny ip any 224.0.0.0 15.255.255.255
access-list 102 permit ip any any
ip access-group 102 in
You cn also combine 102 & 101 into one ACL as you probably know only one ACL per direction is allowed.
If Multicast is not needed at all, just make sure "ip multicast-routing" is not enabled...if so "no ip multicast-routing". I guess this will be easiest way to make sure no Multicast is handled by your access switch.
Sam
06-10-2009 04:32 AM
Hi Sam,
using acl 102 worked fine in a test environment.
Do you know if there is any risk experiencing high cpu load when we activate this acl on all access-ports (2960 with 48 Ports, 3560, ..., 4510R-E with several hundred ports)?
Thorsten
06-10-2009 05:25 AM
not sure about 2960 & 3560...but on 4510R I am using them today , and actually carrying multicast for various IPTV providers with no issues at all...so I think u are prtet safe with E series :-)
Sam
