Community Member
Dropping traffic with a policy-map not working
Hey ya'll. I'm trying to drop traffic using a policy-map. A config snip is included. I see some traffic matching, but it is definitely not being dropped. Any ideas?
policy-map Primary-OUT
class VOICE-Queue
drop
class VIDEO-Queue
drop
class SIGNALING-Queue
drop
class CONTROL-Queue
bandwidth remaining percent 10
blah, blah, blah.
1 ACCEPTED SOLUTION
Community Member
Re: Dropping traffic with a policy-map not working
Hi Kevin,
As per my understanding this QOS configuration will stop dropping packet once the QOS will come into picture ,that is when the congestion will occur until then the traffic will pass .Are you saying there is congestion and even then the traffic is passed.
Chao
Vishwa
Hi kevin,
Which device is this? What IOS you are running. Please paste the config for Class-maps and ACL's as well.
-amit singh
Community Member
Hi Amit. I'm running c2801-advipservicesk9-mz.124-15.T8.bin, but I've tried a similar config in earlier versions of IOS - to no avail.
I can see traffic matching the Edge-IN service-policy on ingress. And when I configure a priority queue (instead of a drop), I can see the same traffic hitting the queue on egress. But when I replace the priority queue with "drop", I see some (but not all) packets hitting the class on egress, but the traffic is definitely not being dropped by the router.
Thanks for your help !
Here is the detail -
class-map match-any BULK-Mark
match access-group name BULK-APPS
class-map match-all SCAVENGER-Queue
match ip dscp af13
class-map match-all SIGNALING-Queue
match ip dscp cs5
class-map match-all VOICE-Queue
match ip dscp ef
class-map match-all VIDEO-Queue
match ip dscp af41
class-map match-all CONTROL-Queue
match ip dscp cs6
class-map match-any SCAVENGER-Mark
match access-group name SCAVENGER-APPS
class-map match-all SIGNALING-Mark
match ip dscp cs5
class-map match-all VIDEO-Mark
match ip dscp af41
class-map match-all VOICE-Mark
match ip dscp ef
class-map match-any CONTROL-Mark
match access-group name CONTROL-APPS
class-map match-all BULK-Queue
match ip dscp af11
policy-map Edge-IN
class SCAVENGER-Mark
set ip dscp af13
class BULK-Mark
set ip dscp af11
class VOICE-Mark
set ip dscp ef
class VIDEO-Mark
set ip dscp af41
class SIGNALING-Mark
set ip dscp cs5
class CONTROL-Mark
set ip dscp cs6
class class-default
set dscp default
class VOICE-Queue
drop
class VIDEO-Queue
drop
drop
class CONTROL-Queue
class BULK-Queue
bandwidth remaining percent 25
random-detect
class SCAVENGER-Queue
police rate 256000
conform-action transmit
exceed-action drop
class class-default
fair-queue
policy-map Primary-Shaper
class class-default
shape average percent 95
service-policy Primary-OUT
interface Loopback0
ip address 1.1.1.1 255.255.255.240
interface FastEthernet0/0
description Internal Interface
ip address 10.1.1.0 255.255.255.0
service-policy input Edge-IN
interface Serial0/1/0
description To MCI
bandwidth 1544
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
max-reserved-bandwidth 100
service-policy output Primary-Shaper
interface Serial0/1/0.500 point-to-point
ip unnumbered Loopback0
frame-relay interface-dlci 500 IETF
ip access-list extended BULK-APPS
permit tcp any any eq 50
permit udp any any eq 60
permit tcp any any eq 70
ip access-list extended CONTROL-APPS
permit udp any any eq 1645
permit udp any eq 1645 any
permit udp any any eq 1812
permit udp any eq 1812 any
permit tcp any any eq telnet
permit tcp any eq telnet any
permit udp any any eq domain
permit udp any eq domain any
ip access-list extended SCAVENGER-APPS
permit ip host 10.16.30.65 any time-range WORKING-HOURS
periodic weekdays 12:00 to 23:59
Community Member
Hi Kevin,
Chao
Vishwa
Community Member
Of course ! I don't know why I didn't think of that. The drop command can't be used to drop all traffic - it will only start dropping when QOS is active. Thanks much Vishwa!
try to attached or apply the policy map on an interface using the 'service-policy' command. try to do a 'show policy-map interface' command afterwards.
1410
