03-17-2008 04:32 AM - edited 03-05-2019 09:48 PM
I have configured a 1811 for dual WAN using two default routes and tracking it with IP SLA. I am also using route maps for nat.
Here is my relevant config on the 1811.
ip sla 1
icmp-echo ip1 source-interface FastEthernet1
timeout 1000
threshold 30
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo ip2 source-interface FastEthernet0
timeout 1000
threshold 30
frequency 3
ip sla schedule 2 life forever start-time now
track 100 rtr 1 reachability
track 101 rtr 2 reachability
ip route 0.0.0.0 0.0.0.0 ip1 track 100
ip route 0.0.0.0 0.0.0.0 ip2 track 101
ip nat inside source route-map ISP1 interface FastEthernet0 overload
ip nat inside source route-map ISP2 interface FastEthernet1 overload
access-list 100 permit ip 172.16.30.0 0.0.0.255 any
route-map ISP1 permit 10
match ip address 100
match interface FastEthernet0
route-map ISP2 permit 10
match interface FastEthernet1
This is working fine for outgoing traffic.
Now I want to direct all inbound traffic to a particular internal IP(ex 172.16.30.1). This can be either from both isp's or even from one.
How can I achieve this?
I tried a static nat translation in addition with the route map nat entires (ip nat inside source static 172.16.30.1 interface fa1) but then it began using only the ISP with the static nat statement(only fa1) and load balancing stopped working.
Any ideas?
Alex
03-21-2008 09:29 AM
Have a look at this configuration examples guide.
http://www.cisco.com/en/US/products/ps5853/tsd_products_support_configure.html
03-21-2008 10:25 AM
Thanks but there is nothing related to what I was asking.
Those are just basic configuration guides.
05-09-2008 04:24 PM
Ok what you will need to do is configure both static and dynamic Nat on each interface. I know I have done that on 1 wan routers before but using the same configs I have not been able to recreate this on an 1811. I have had to chose one or the other per interface.
If anyone knows of a way to do this I would love to know it.
