Dual C2960 Nic Teaming
i have this senario as Shown in to the Pic
          i have to power of one Of the Switches so the Servers(using NIC Teaming Feature Indepndent Switch) can be Reachable otherwise when the 2 switches is on i lost Connection
          configuration on both Switches is the Same Mirror
          so can any body advice me
Everyone's tags (3)
Hall of Fame Super Gold
Can't be done.
The switches must form a logical stack.  Like a 2960S or a 3750, 3850 or 3650.
can you explain why what exaltly preventing on current switchs
Ok, look at this from this point of view ...
If you have two 2960S/X, 3750, 3650 or 3850 and they form a single switch, then you can easily form an etherchannel even though the NICs are going to two physical switch.
How can you form an etherchannel from two plain-2960 switch to a single server?  You can't.
ok
if i need to look to this in deep which Refersnce i can use like CCNP -SWITCH Book or somewhere else can you specify it to me Please
Check out this document:  Configuring EtherChannels and look at Figure 37-3.
thank you very much
also i noted that there is no mac - address come from the 2nd switch to the first FW becuase i though that the 2nd link whiches go to the 2nd switch is active , it was and still stand by the the default behavior of thr redundant interface on the FW
but i think to fix that work with 2960S Stack with ethernetchannel on the firewall what do you thing
BR
That's correct.  The NIC ports need to go to a single LOGICAL switch.  If you stack, say, two or more of their 3750, 3650, 3850, 2960S/X, then what you are doing is creating a single LOGICAL switch.  This will enable etherchannel across multiple PHYSICAL switch.
366
