04-27-2009 01:02 AM - edited 03-06-2019 05:24 AM
Dear Experts,
We have 6506 Core switch with 2 SUP card. in Last week one was become faulty and now I have replaced it with new one.
During the time other SUP is in designated mode and working ok. NW is UP. System is configured with HSRP.
Now the steps I had taken for replaceing it are :
1. Plug the new SUP card in slot.
2. Console it and configured High Avialability + Config Sync.
3. In a second the whole cofiguration was coppied in new Card.
But the the problem i found that the HSRP priority was not seen in new Card ..Rest of the config is there in new Card ?
I am showing the part of config for both the SUP.
SUP - 1 which is active with Priotiry 115 as shown : Designated
Config:
mls rp ip
redundancy
high-availability
config-sync
interface Loopback0
ip address 192.168.201.251 255.255.255.0 alt ip address 192.168.201.252 255.255.255.0
interface Vlan100
description ***** System VLAN *****
ip address 10.15.101.32 255.255.255.0 alt ip address 10.15.101.34 255.255.255.0
no ip redirects
standby 2 priority 120 preempt alt standby 2 priority 115
standby 2 ip 10.15.101.35 alt standby 2 ip 10.15.101.35
hold-queue 125 in
line con 0
exec-timeout 0 0
line vty 0 4
exec-timeout 0 0
password _______________
login local
transport input lat pad mop telnet rlogin udptn nasi
ntp clock-period 17180048
ntp server 10.15.102.52
end
SUP - 2 Which is not active and in nondesignated MOde
Config:
mls rp ip
redundancy
high-availability
config-sync
interface Loopback0
interface Vlan100
no ip redirects
hold-queue 125 in
line con 0
exec-timeout 0 0
line vty 0 4
exec-timeout 0 0
login local
end
Why this happen and how to resolve it ...
pls suggest the steps....or docs...
Dipesh P.
04-27-2009 02:55 AM
Dipesh,
Generally, when we have set the standby priority to 100 (default vaue) we will not be seeing the configuration command present as this is the default configuration.
04-27-2009 07:23 PM
Dear Deepa,
Yes you r right. But I have the priority which one is in 1st SUP card nned to be sync in other SUP card automatically but it was not ..... than how Can i add now .......??
If I will remove config sync from the Active SUP than weather it will affect the NW ??? Will it make NW down ???
What should I do ?
Can you suggest ?
Dipesh P.
04-27-2009 09:23 PM
Please provide the output of:
sh ver & sh redundancy
04-27-2009 10:28 PM
Dear Deepa,
For SUP 1 :
sh ver
IOS (tm) MSFC2 Software (C6MSFC2-JSV-M), Version 12.1(8b)E6, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 28-Nov-01 19:11 by hqluong
Image text-base: 0x40008980, data-base: 0x418D2000
ROM: System Bootstrap, Version 12.2(17r)S1, RELEASE SOFTWARE (fc1)
BOOTFLASH: MSFC2 Software (C6MSFC2-JSV-M), Version 12.1(8b)E6, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
POY_MSFC2 uptime is 42 weeks, 3 days, 1 hour, 25 minutes
System restarted at 10:21:11 IST Sat Jul 5 2008
System image file is "bootflash:c6msfc2-jsv-mz.121-8b.E6.bin"
cisco Cat6k-MSFC2 (R7000) processor with 229376K/32768K bytes of memory.
Processor board ID SAD050207XS
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
57 Virtual Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x102
sh redundancy
Designated Router: 2 Non-designated Router: 1
Redundancy Status: designated
Config Sync AdminStatus : enabled
Config Sync RuntimeStatus: enabled
Single Router Mode AdminStatus : disabled
Single Router Mode RuntimeStatus: disabled
For SUP 2 :
sh ver
IOS (tm) MSFC2 Software (C6MSFC2-JSV-M), Version 12.1(26)E3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 15-Aug-05 10:43 by ccai
Image text-base: 0x40008F90, data-base: 0x41C42000
BOOTLDR: MSFC2 Software (C6MSFC2-JSV-M), Version 12.1(26)E3, RELEASE SOFTWARE (fc1)
POY_MSFC2 uptime is 2 weeks, 22 hours, 59 minutes
System restarted at 12:51:33 IST Mon Apr 13 2009
System image file is "bootflash:c6msfc2-jsv-mz.121-26.E3.bin"
cisco MSFC2 (R7000) processor with 229376K/32768K bytes of memory.
Processor board ID SAD0552068R
Bridging software.
56 Virtual Ethernet/IEEE 802.3 interface(s)
sh redundancy
Redundancy Status: non-designated
Single Router Mode transition timer : 120 seconds
Dipesh P.
04-27-2009 09:17 PM
Hi Dipesh,
Is the replacement card running the same IOS as the current one?
04-27-2009 10:27 PM
For SUP 1 :
sh ver
Bridging software.
sh redundancy
For SUP 2 :
sh ver
Bridging software.
sh redundancy
Sir Pls find the sh ver and sh redundancy output for both card ....
Dipesh P.
04-27-2009 10:30 PM
SUP 1 : bootflash:c6msfc2-jsv-mz.121-26.E3.bin
SUp 2 : bootflash:c6msfc2-jsv-mz.121-8b.E6.bin
There is an IOS version mismatch found. Please make sure that both the Supervisor are running with the same image.
04-27-2009 10:33 PM
Check Configuration register value as well :
Configuration register needs to be 0X2102.
04-28-2009 12:08 AM
Dear Deepa,
Ya it's clear that IOS is mismatched and that is the reason why confug sync is not working.
So should I need to replace IOS in new one with the same is working in old card?
or what you suggest ?
And i think there may not be any problem with config reg as it the same in both of these SUPs as well as the same in other Core chassis two MSFCs.
Pls reply soon.
Dipesh P.
04-28-2009 12:26 AM
It's recommended to have the new card to be operating with the same IOS as the existing IOS on the old card.
{We already know that the IOS in the old card is compatible to your Network setup & running fine. So, it's better if you can boot the new card with the same IOS}
04-28-2009 09:11 PM
If I will change the IOS than I need to reboot the SUP Card .
It is ok to do it by unpludg the card and reinsert it.
Will it be affect the the running network ?
Dipesh P.
04-28-2009 09:51 PM
You can use the commands below:
copy bootflash:filename.bin slavebootflash:filename.bin
redundancy reload peer
04-29-2009 08:24 PM
Dipesh,
This will not affect your production. You will just be reloading the standby-sup module using the command- 'redundancy reload peer'
