01-16-2009 08:39 AM - edited 03-06-2019 03:29 AM
Is it possible to set up dual ethernet connections to the LAN on a router? I want to do this without configuring two IPs. All the LAN gear will still need to point to one GW. Also, the two ports can be connected to the same switch for this config. Thanks.
01-16-2009 08:57 AM
Michael
You can use IRB (Intergrated Routing & Bridging) to achieve this. Be aware though that one of the links to the switch will block due to STP -
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_tech_note09186a0080094663.shtml
Jon
01-16-2009 09:23 AM
Possible option might be to use Etherchannel.
01-23-2009 08:58 AM
Does anyone know if a IAD 2431 supports Etherchannel?
