Community Member
Dual-homed servers to switches
I have dual-homed some servers to my switches from the server end. Only one NIC card is active at all times and if the primary one fails, the backup takes over. What's the best practice on the switch end about portfast? Should I enable it on both ports or disable it?
Thank you
1 REPLY
Blue
Re: Dual-homed servers to switches
Enable portfast and bpdu guard on both ports.
280
