Dual homed to single isp config
Dear All,
In the LAN network 4507R as core switch configured with several vlans.One vlan connects to the dual homed routers which in turn connecting to the single isp. I need to configure the HSRP for the internal vlans and the same time to use the load balancing or failover using the dual homed routers to the isp.
Please how can i do the config. I need to implement for the banking customer tomorrow.
swamy
1 REPLY
Hall of Fame Super Silver
Re: Dual homed to single isp config
swamy
You have posted exactly the same question on the WAN Routing and Switching forum. For the sake of efficiency I suggest that any discussion consolidate on that forum.
Rick
173
