Dual ISP NAT Question
mtehonica
Level 5
Level 5
Here is my situation... I have dual ISP configured on my ASA 5505.  I need to NAT serveral servers on the inside to public IPs on the outside.
Example:
Web Server Private IP: 192.168.5.11
Public IP from ISP 1: 96.249.40.40
Public IP from ISP 2: 208.125.237.80
Here is my config:
ASA Version 8.4(1)
hostname nysyr-sbo-asa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan2
description Connection to Primary ISP (FiOS)
nameif primaryisp
security-level 0
ip address 172.31.150.25 255.255.255.0
interface Vlan3
description Connection to Secondary ISP (Time Warner)
nameif backupisp
security-level 0
ip address 10.10.10.25 255.255.255.0
interface Vlan5
description Connection to internal internet access subnet (192.168.5.0/24)
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
switchport access vlan 5
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
object network primaryisp-network
subnet 172.31.150.0 255.255.255.0
object network backupisp-network
subnet 10.10.10.0 255.255.255.0
object network inside-network
subnet 192.168.5.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu primaryisp 1500
mtu backupisp 1500
ip local pool vpn-ip-pool 10.20.20.10-10.20.20.30 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,primaryisp) source dynamic any interface
nat (inside,backupisp) source dynamic any interface
access-group global_access global
route primaryisp 0.0.0.0 0.0.0.0 172.31.150.254 1 track 1
route backupisp 0.0.0.0 0.0.0.0 10.10.10.254 10
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.5.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
sla monitor 123
type echo protocol ipIcmpEcho 8.8.8.8 interface primaryisp
threshold 3000
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
telnet timeout 5
ssh timeout 5
console timeout 0
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
5 Replies 5
Pawan Sharma
This is something which is generally not recommended if used simultaenously. what you can do is configure it along with IP SLA and use them with automated failover.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
Thanks for the reply.  As you can see from the config, I am using IP SLA to failover from primaryisp to backupisp.  What I need to figure out is how to handle this situation when a failover happens.
You dont have to handle this manually. In case of failover ASA will rebuild the NAT table and would the same for your static NATs too.
Pawan Sharma
Pawan Sharma
https://itgears.io
How would it do it automatically?  I have to tell it what to NAT. For example...
object network asp-wss-1
nat (any,any) static 208.125.237.80
How do I also tell it to nat (any,any) static 96.249.40.40??  Would I need to create 2 unique objects with 2 unique private IPs?
For anyone else who comes across this issue, here is what I ended up doing...
Create 2 objects with the same IP...
object network asp-wss-1-tw
host 192.168.5.11
object network asp-wss-1-vz
host 192.168.5.11
Then NAT each of those to their respective IPs for that ISP...
nat (inside,backupisp) static 208.125.237.xxx
nat (inside,primaryisp) static 24.97.182.xxx
