dual static next hop to the same dest
what will happen if i have the ff command on my perimeter router
ip route 10.0.0.0 255.0.0.0 192.168.1.1
ip route 10.0.0.0 255.0.0.0 192.168.1.2
192.168.1.1-firewall 1
192.168.1.2-firewall 2
1 REPLY
Hall of Fame Super Blue
Re: dual static next hop to the same dest
Your permimeter router will load balance between the 2 firewalls. Whether it does it per packet or per destination depends on how you setup the router.
You need to be careful with this as you may well get asymetric routing - goes out one firewall and comes in the other. If your firewall are active/active this may not be a problem but it could be if you are running in active/standby.
Jon
94
