Duplex Mismatch between Cisco 2960 (LANBase Image) and Cisco 6506 Switch
edwardwaithaka
I have the following issue;
I am getting a duplex mismatch between a Cisco 2960 TT-L Switch running IOS 12.2(35) LAN Base Image (Gig0/1) and a Cisco 6506 Switch running IOS 12.2(33)SXH Adv IP Services (Gig2/19).
I have tried several combinations of the duplex/speed settings on both sides but the only that works is setting duplex/speed AUTO on the Cisco 2960 which ends up autonegotiating to HALF duplex and 100Mbps.
What cou;d be the issue? IOS bugs?
Edd.
9 Replies 9
arianto.wibowo
is it using UTP cable ?
please try to replace with another cable.
edwardwaithaka
I have upgraded the Cisco 2960 Switch to version 12.2(52). The interfaces are now at FULL duplex but cannot negotiate to 1000Mbps.
zvondovec
Can you put here results of sh run int ... commands?
thnx
Ports are on default;
2960
int gig0/1
switchport mode access
switchport access vlan zzz
duplex auto
speed auto
6500
int gig2/18
no switchport
ip address x.x.x.x y.y.y.y
no speed
no duplex
Is there only cable between those 2 boxes, or is there some convertor (fiber optic)?
Also you can try speed nonegotiate command on both sides.
bye
vvasisth
i am pretty sure i saw a similar bug.
Varun
Leo Laohoo
On both, try the following interface command "speed auto 1000".
  It is generally advised you use auto on both sides for gigabit. If they are not negotiating gig then I would take a serious look at the cabling . Unlike fastether which takes 2 pairs you must have 8 good wires in the entire path between the 2 devices  in order to negotiate gig as gig uses all 8 wires to achieve gig speeds . Even 1 bad wire out of the 8  it will not negotiate gig .  Make sure speed negotation is actually turned on for the 6500. you can check this with the following counterintuitive  command
no speed nonegotiate .  Verify with the command
show interfaces GigabitEthernet slot/port transceiver properties
Good info for explaining the different states for gig port settings.  http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/intrface.html#wp1020621
On the 2960 switch the "dual purpose" uplinks need to be manually configured with "media-type" to be able to set speed/duplex. Default would not allow setting these 2 attributes.
interface GigabitEthernet0/1
switchport mode trunk
media-type rj45
speed 100
duplex full
end
GigabitEthernet0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is
Description: Uplink to Cat01
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swint.html#wp2219831
