DUPLEX_MISMATCH - both ends are Full
2611 Ethernet port connecting a 3650 switch:
duplex mismatch discovered on Ethernet0/0 (not full duplex), with 3560G GigabitEthernet0/5 (full duplex)
now this is the E0/0 interface config:
interface Ethernet0/0
description LAN on VLAN42
ip address 192.168.42.3 255.255.255.0
full-duplex
end
why do I get this error if E0/0 is configured to full?
Purple
Re: DUPLEX_MISMATCH - both ends are Full
Some of the early 2600 series even though the full-duplex command was there it did not in fact actually make the connection full duplex so it could really be running half duplex . We used to see that when we ran those early 2600's .
Hall of Fame Super Bronze
Post the switchport config portion from the 3560G switch.
__
Edison.
interface GigabitEthernet0/5
description Barak 192.168.42.3 via BranchOffices
switchport access vlan 42
switchport mode access
duplex full
speed 10
spanning-tree portfast
end
Looks good. It sounds like Glen is on target. Personally, I haven't seen that problem before but I trust Glen :)
Try upgrading the IOS in the 2600 router and see if that helps.
__
Edison.
this is the version details:
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(5)T7
yes, it is old...
now there are 2 questions:
1. does it show not-full on E0/0 but work as full? because I care for performance not for the messages
2. if I upgrade, which version should I use (or what is the earliest version that fix this problem)?
thanks
Ofir
1) It is using half-duplex, not full-duplex. It could be due to the old IOS version.
2) Please post show version in order to make the proper recommendation.
BranchOffices#sh ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(5)T7, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 16-Apr-01 20:38 by ccai
Image text-base: 0x80008088, data-base: 0x809719E0
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-I-M), Version 12.1(5)T7, RELEASE SOFTWARE (fc1)
BranchOffices uptime is 35 weeks, 3 days, 12 hours, 32 minutes
System restarted at 22:59:23 EST Mon Oct 1 2007
System image file is "flash:c2600-i-mz.121-5.T7.bin"
cisco 2611 (MPC860) processor (revision 0x203) with 27648K/5120K bytes of memory
c2600-i-mz.123-26.bin should meet your needs.
__
Edison.
Please rate helpful posts
duplex full
speed 10
end
Found a similar issue -
CSCdx73746
3640 running 12.1(5)T12 code accepts full duplex command for ethernet interface but it doesn't work. Devices connected to the port show 10Mbps. Half Duplex.
12.1(5)T7 is also affected.
I also remebber something like this happening long time back. Can't recall which router it was but there was some etherne interface whcih doesn't support full duplex.
Can you paste the show interface output just to check the hardware.
-> Sushil
BranchOffices#sh int e0/0
Ethernet0/0 is up, line protocol is up
Hardware is AmdP2, address is 0005.3286.7ca0 (bia 0005.3286.7ca0)
Description: LAN on VLAN42
Internet address is 192.168.42.3/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w4d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 5 drops
5 minute input rate 2000 bits/sec, 4 packets/sec
5 minute output rate 2000 bits/sec, 3 packets/sec
6578472 packets input, 1539704903 bytes, 0 no buffer
Received 1069818 broadcasts, 0 runts, 0 giants, 0 throttles
5466012 packets output, 657579877 bytes, 0 underruns(0/0/0)
1 output errors, 0 collisions, 0 interface resets
1 lost carrier, 0 no carrier
I am having a similar issue between a 3640 router and a 3560G switch. The only way I can get the link to come up is to code the port on the 3640 as half-duplex. I have two ethernet ports on the router and I am going to try switching ports to see if it is a hardware issue. I would think that the best thing to do would be to code both ports 10/full.
267
