Community Member
duplex mismatch
which is which? I have a FE port configured half duplex and other side GE full duplex whats the impact. Is it better to set on auto? How about the speed? any url for reading? thanks
Re: duplex mismatch
Hi Korbenda,
If you have half duplex on one side or duplex on another side you will see lot of collision errors on your interface.
I will recommed to set it on auto and let the interface negotiates itself the speed and duplex or you can manually set the speed on gig interface to 100 to match the fast ethernet interface on other side.
Ankur
Gold
Re: duplex mismatch
Community Member
Re: duplex mismatch
thanks!
Community Member
Re: duplex mismatch
thanks!
158
