Duplicate mac-addresses on CAT 6513 - Is this a problem?
6513-#sh mac-address-table address 0007.b32b.d2c0
Legend: * - primary entry
        age - seconds since last seen
        n/a - not available
  vlan   mac address     type    learn     age              ports
Supervisor:
*  110  0007.b32b.d2c0    static  No           -   Router
*  100  0007.b32b.d2c0    static  No           -   Router
*  210  0007.b32b.d2c0    static  No           -   Router
*  220  0007.b32b.d2c0    static  No           -   Router
*  200  0007.b32b.d2c0    static  No           -   Router
*  230  0007.b32b.d2c0    static  No           -   Router
*  460  0007.b32b.d2c0    static  No           -   Router
*  496  0007.b32b.d2c0    static  No           -   Router
*  495  0007.b32b.d2c0    static  No           -   Router
*  330  0007.b32b.d2c0    static  No           -   Router
*  320  0007.b32b.d2c0    static  No           -   Router
*  340  0007.b32b.d2c0    static  No           -   Router
*  350  0007.b32b.d2c0    static  No           -   Router
*  380  0007.b32b.d2c0    static  No           -   Router
*  360  0007.b32b.d2c0    static  No           -   Router
*  ---  0007.b32b.d2c0    static  No           -   Router
*   50  0007.b32b.d2c0    static  No           -   Router
*    7  0007.b32b.d2c0    static  No           -   Router
*    1  0007.b32b.d2c0    static  No           -   Router
*    9  0007.b32b.d2c0    static  No           -   Router
*  190  0007.b32b.d2c0    static  No           -   Router
*  180  0007.b32b.d2c0    static  No           -   Router
*  420  0007.b32b.d2c0    static  No           -   Router
*  390  0007.b32b.d2c0    static  No           -   Router
*  310  0007.b32b.d2c0    static  No           -   Router
*  300  0007.b32b.d2c0    static  No           -   Router
*  280  0007.b32b.d2c0    static  No           -   Router
The above MAC addresses are the BIA ( Burnt in addresses of many ports in this CAT 6513 ) and can also be seen when doing show interface command as follows:
Partial Output:
Vlan7 is up, line protocol is up
  Hardware is EtherSVI, address is 0007.b32b.d2c0 (bia 0007.b32b.d2c0)
  Description: GCAOA 2 NAL - Link 1
  Internet address is 10.120.253.225/29
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 2/255, rxload 2/255
  Last input 00:00:02, output 00:00:00, output hang never
  Input queue: 0/75/278/278 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 9307000 bits/sec, 1767 packets/sec
  5 minute output rate 8782000 bits/sec, 1780 packets/sec
  L2 Switched: ucast: 362482 pkt, 32307959 bytes - mcast: 956576 pkt, 85398380 bytes
  L3 in Switched: ucast: 1867504285 pkt, 1443931102771 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 1815701229 pkt, 961832705341 bytes mcast: 0 pkt, 0 bytes
     1868623791 packets input, 1444029196575 bytes, 0 no buffer
     Received 757142 broadcasts (757142 IP multicast)
     1816765552 packets output, 961914556799 bytes, 0 underruns
     0 output errors, 0 interface resets
Vlan9 is up, line protocol is up
  Description: Communications - GWAN
  Internet address is 10.120.253.251/28
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/1/1 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 10929000 bits/sec, 2124 packets/sec
  5 minute output rate 10061000 bits/sec, 2228 packets/sec
  L2 Switched: ucast: 12295147 pkt, 1330274178 bytes - mcast: 6861848 pkt, 506128599 bytes
  L3 in Switched: ucast: 2198266998 pkt, 1224275689345 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 2552911947 pkt, 1847139656199 bytes mcast: 0 pkt, 0 bytes
     2214829509 packets input, 1225864174517 bytes, 0 no buffer
     Received 6861858 broadcasts (2358354 IP multicast)
     2565064604 packets output, 1848442726830 bytes, 0 underruns
Vlan10 is administratively down, line protocol is down
  Description: Management Vlan (not in production yet)
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicast)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 1 interface resets
Everyone's tags (1)
Silver
Re: Duplicate mac-addresses on CAT 6513 - Is this a problem?
this is normal and expected
I thought so. But can this be explained with a reason which is what the customer is asking.
Hall of Fame Super Silver
Hello Alphonse,
the choice in Cisco multilayer switches is to use the same MAC address for all SVI interfaces
0007.b32b.d2c0
this is not a problem because CAM tables use Vlan, MAC address, port so it does not create ambiguities.
The device has a block of MAC addresses that can be seen with sh module but it uses only one.
The same happens for STP with extended system-id option.
In each Vlan an ARP request for SVI IP address will get the answer 0007.b32b.d2c0
There are specific cases when you need to assign a different MAC address to an SVI and this can be done with mac-address command like in this example:
router#sh run int vlan 617
Building configuration...
Current configuration : 355 bytes
interface Vlan617
description xxxx
mac-address 000e.847e.87c2
mtu 1520
ip address 10.82.8.98 255.255.255.240
ip pim dr-priority 10
ip pim sparse-mode
Edit:
Ganesh in another thread has found a link that explains support of same MAC address on multiple SVIs that can help
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c9b4e.shtml
Hope to help
Giuseppe
1649
