duplicate udp nat entries
We have a NAT issue at our office. Every now and then we lose our SIP registration.  When that happenes and I use the show ip nat translation command I see two udp nat entries with the same inside global and outside global address+port. I anonymised the inside global address. After I use the clear ip nat * command the duplicate entries are gone and two inside global addresses with two different port numbers are used. I found a similar but different problem:
https://supportforums.cisco.com/thread/160079 which describes the use of duplicate udp entries for different outside global addressses.
Pro Inside global         Inside local          Outside local         Outside global
udp 195.191.X.X:1037   10.1.2.244:5060       213.239.5.69:5060     213.239.5.69:5060
udp 195.191.X.X:1037   10.1.2.46:5060        213.239.5.69:5060     213.239.5.69:5060
IOS version:
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(3)T, RELEASE SOFTWARE (fc1)
Does anyone know if this is a know bug, if there is a workaround, if the bug is solved in a newer IOS version?
Kind regards,
Sebastiaan
Everyone's tags (4)
349
