DVMRP Tunnelling
I have to get some multicast traffic across a non multicast network, and have had a suggestion I use DVMRP tunnels. The site routers are 3750, so no GRE,.
Try as I might, I don't seem to get it working - I don't think the tunnel it establishing properly , a sh int shows nothing in or out. A debug ip pack with an access list to the tunnel destination shows nothing.
sh int tu0
Tunnel0 is up, line protocol is up
Hardware is Tunnel
Interface is unnumbered. Using address of Vlan512 (10.50.12.11)
MTU 9112 bytes, BW 100 Kbit, DLY 50000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 10.50.99.11 (Loopback0), destination 10.50.99.10
Tunnel protocol/transport IP/IP (DVMRP)
Tunnel TTL 255, Fast tunneling enabled
Tunnel transport MTU 1480 bytes
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
IOS is 12.2(50)se.
Any suggestions about what I have wrong?
Community Member
Re: DVMRP Tunnelling
You can configure a DVMRP tunnel on a router if the other end is running DVMRP. The software then sends and receives multicast packets over the tunnel. This strategy allows a PIM domain to connect to the DVMRP router in the case where all routers on the path do not support multicast routing. You cannot configure a DVMRP tunnel between two routers.
Thanks for the confirmation - I had kind of come to the conclusion that to do the tunnel, it would need to be a real DVMRP tunnel at the other end.
194
