11-18-2010 01:39 PM - edited 03-06-2019 02:07 PM
Is it possible to setup DYDNS on a Cisco 861 router? If yes, what IOS version do I need? thanks for your time!
11-18-2010 03:13 PM
I assume you mean Dynamic DNS.
Yes, it is supported. See:
Do you use Cisco Configuration Professional, or the command line?
11-19-2010 05:26 AM
Phil, thanks for the response! Well, I woudl like to use Config Pro, but I have not been able to get it to run on my
Windows 7 64-bit machine. Going to have to see if anyone else has experienced this. Unfortunately, I have not yet mastered the command line interface.
11-22-2010 03:14 PM
Do send a mail to ccp-feedback@cisco.com regarding your issues with CCP and 64 bit Windows.
11-23-2010 06:23 AM
Got it to work
by setting it to XP SP3 compatibility mode. Thakns for your help!
11-23-2010 06:25 AM
I have also had the experience that running it in "Administrator Mode" causes it to work in some cases, too.
11-19-2010 01:26 AM
Hi ,
Please check this config example hope it will help.
Syed.
11-19-2010 05:26 AM
Thanks Syed, I will take a look!
