DYDNS on Cisco 861 router?
jdanie01
Is it possible to setup DYDNS on a Cisco 861 router? If yes, what IOS version do I need? thanks for your time!
7 Replies 7
Phillip Remaker
I assume you mean Dynamic DNS.
Yes, it is supported.  See:
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iad_ddns_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Do you use Cisco Configuration Professional, or the command line?
Phil, thanks for the response! Well, I woudl like to use Config Pro, but I have not been able to get it to run on my
Windows 7 64-bit machine. Going to have to see if anyone else has experienced this. Unfortunately, I have not yet mastered the command line interface.
Do send a mail to ccp-feedback@cisco.com regarding your issues with CCP and 64 bit Windows.
Got it to work
by setting it to XP SP3 compatibility mode. Thakns for your help!
I have also had the experience that running it in "Administrator Mode" causes it to work in some cases, too.
sfaizul
Thanks Syed, I will take a look!
