Dying-Gasp
I don't knows if my CORE 6506 support dying-gasp feauture. Somebody could send me a chart with all cisco plataform that support Daying-gasp option?
http://networkingcontrol.wordpress.com/ #CCNP CSCO11962956
Green
Hi,According to the Dyin Gasp
According to the Dyin Gasp config guide
http://www.cisco.com/c/en/us/td/docs/routers/connectedgrid/cgr2010/software/15_2_3_t/configuring_dying_gasp.pdf
This feature is only supported on:-
Feature Hardware Minimum Software Release
Dying Gasp
Cisco CGR 2010 Cisco IOS Release 15.2(3)T
Cisco CGS 2520 Cisco IOS Release 15.0(2)XE
Hope this helps
Regards Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Hi Alex,I believe that the
Hi Alex,
I believe that the Dying Gasp should be available across a wider platform set but unfortunately, I was not able to find any specific document for 6500 series Catalysts. In any case, for Ethernet-based cards on Catalyst 6500, the relevant support would actually be the Ethernet OAM, specifically, Remote Failure Indication (RFI). This document describes it in more detail:
http://www.cisco.com/c/en/us/td/docs/ios/cether/configuration/guide/ce_oam.html#wp1053845
I've got a feeling that the prerequisite for this are line cards that support Ethernet OAM. As I said, though - I couldn't find any particular document for that.
Best regards,
Peter
190
