11-23-2006 01:53 PM - edited 03-05-2019 01:00 PM
Will dynamic NAT and PAT work on a same router.If not why?
If there is any link briefing the concept please let me know.
11-23-2006 07:12 PM
See Dynamic NAT comes into picture when you have got some number of IPs and you want to use them all for NAT.
PAT comes into picture when you are having only one single IP and you want to NAT the whole subnet.
So by taking range of IPs you can do Dynamic NAT for one subnet and do PAT with single IP for another subnet.
Hope that helps,
Suresh Jain
11-25-2006 02:21 AM
in addition u can use the same subnet for PAT.So once all the dynamically IP's are used then PAT is going to take place.
Mahmood
11-25-2006 03:00 AM
Hello
Here is link for NAT from Cisco.com
http://www.cisco.com/warp/public/556/nat-cisco.shtml
but if you have any copy of ROUTING TCP/IP VOLUME-II BY JEFF DOYLE than its best explanation for NAT. see part 2 chepter 4.
regards
Dhaval
