Dynamic Routing and IP Address of PCs
Muhammad Haseeb
In a case, if we have router interface and PCs connected to router then we have to declare Pcs Ip address in Dynamic routing  if using RIP 1/2 or EIGRP. But what if we have switched connected to router and having more  than 40 PCs . Do we have to type each pc addressss when creating dynamic routing?
7 Replies 7
John Blakley
Muhammad,
I'm not sure I understand your question, but routing protocols are for devices to exchange routing information with each other. You don't need to put 40 pc addresses in your routing protocol unless they're on 40 different subnets (vlans). For example, if you have 192.168.1.0/24 as your network, you can have 254 hosts (1 - 254) on that network. In your routing protocol, you'd only route for 192.168.1.0 255.255.255.0. The router knows that it can get to anything on the local subnet (192.168.1.0/24) by going out its lan interface.
HTH,
John
Please rate useful posts...
HTH, John *** Please rate all useful posts ***
Your answer is perfect as per his question. Once my student asked me same question.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
fb_webuser
Level 6
Level 6
As John said, you just need to specify the subnet of the PC's ip addresses.
Posted by WebUser Kapil Pathak from Cisco Support Community App
fb_webuser
Level 6
Level 6
save yourself some trouble, just use redistribute connected command under eigrp....
Posted by WebUser Neeraj Jagga from Cisco Support Community App
fb_webuser
Level 6
Level 6
We featured your question on our page. Check out the responses here http://www.facebook.com/CiscoSupportCommunity/posts/394020573954570
Posted by WebUser Cisco NetPro from Cisco Support Community App
fb_webuser
Level 6
Level 6
Follow exactly as what j.blakley said. Even you can't have 40 PC with different subnet which connected to single vlan and single Router interface. Just advertise the whole subnet.
Posted by WebUser Nagiswaren Utheyakumar from Cisco Support Community App
fb_webuser
Level 6
Level 6
Nothing to do !!!!! Just advertise your ip subnet using network command. if they are in different subnets, u need to go for vlans in switch and sub-interfaces in router( Router on a Stick)...
Posted by WebUser Janardhan Rao Meesala from Cisco Support Community App
