Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
E&M interface (VIC2-2E/M)
Hi.
Is it possible to connect between two routers using their E%M interfaces and ping through the routers between two PCs (the ethernet interfaces do have ip addresses)?
Thank you.
4 ACCEPTED SOLUTIONS
Re: E&M interface (VIC2-2E/M)
Hi Danny,
Never tried this but looks like you can do this.
Here's what mentioned in one of the cisco document -
"The Cisco analog E&M interface functions as the signaling unit side and it expects the other side to be a trunk circuit. When you use E&M interface models Type II and Type V, two signaling unit sides can be connected back to back by the appropriate crossing of the signaling leads. When you use E&M Type I interfaces, two signaling unit sides cannot be connected back to back." -
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080093f60.shtml
This link talks about the wiring -
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_tech_note09186a008009452e.shtml
Goold luck mate.
-> Sushil
Blue
In short, no.
The E&M interfaces allow for analog telephony connectivity and does not support digital layer 3, or layer 2 addressing so pushing digital packets through them can not work.
An E&M interface connects the cisco device to a telephony trunk with analog signaling for communication to a connected analog interface such as that in a PBX or telco.
The links mentioned in the above post will clearly explain what E&M can do and pushing packets is not possible.
Danny/Greg,
I overlooked PC to PC communications.
Not possible Danny.
-> Sushil
E&M is a form of analog telephone circuit used for PBX trunks. Not suitable for packet-based data communication. With the proper wiring you could use two E&M circuits back-to-back as a voice link for telephony.
Not suitable for IP, however.
Hi Danny,
Goold luck mate.
-> Sushil
Blue
In short, no.
Danny/Greg,
Not possible Danny.
-> Sushil
Thank you.
Danny.
802
