Webcast-Catalyst9k
e1 connection
Hi all, i believe you can have e1 connections point to point, in that case why would you run frame relay over an e1 or serial connection ?
Re: e1 connection
can anyone please help me on this ?
Re: e1 connection
Hi Carl
AFAIK you can have different frame relay sub interfaces to have different sets of services availed from the SP.
The SP should be able to provide both the services from the same PE router where the customer link is getting connected.
regds
116
