e1 wic max bandwidth
carl_townshend
Hi all, can anyone tell me what the max bandwidth is on a cisco e1 wic??
cheers
Carl
huljoscttu
It depends on which specification of wic you are using. Search "wic" in the cisco search box, and it will give you different listings to look at.
hello,
Any where the max e1 bandwidth / speed is 218 kbps is it right or not?
naidu
mohammedmahmoud
Level 11
Level 11
Hi Carl,
The maximum speed on an E1 WIC is 2M.
HTH,
Mohammed Mahmoud.
